So backstory.... my wife was mowing with my 73 110 and everything was great, but then all of a sudden it started sputtering and running real choppy then eventually died. I suspected the coil, so I let it cool off and re started it to put it away and it started and ran but acted like there was a bad ground, ran really choppy and missed a lot.
I pulled it in the garage, put my spark tester on and started it. I could see a spark but it was weak and intermittent. I replaced the coil with the correct internally resisted coil but it had the same symptoms.
I filed and cleaned and gapped the points, but didn't change anything. I then decided to install new points and condenser. Now I've got a real strong spark, but it's still erratic and after about 30 to 45 seconds I lose it again. It'll start right back up, but then repeats itself.
I have no idea what to check now. I put a known good spark plug wire on which changed nothing. I don't know if something is wrong with the magnets, or if the new coil is bad. What should I do?
Sent from my SM-G960U using Tapatalk
