1 - 2 of 2 Posts
I need help with 2 issues that I am having with a '93 GT 6000.
1. First issue, I would like some advice as to which is the best way to adjust the lifters/valves on a Kohler m18.
2. I am having problems with the 6 speed transaxle, when I shift into any gear on the left side of the trans (5/2 or 4/1 ) all I get is a slow speed regardless of which gear it is in. The gears on the right side of the trans are fine 3/6 and reverse high and low is fine, any ideas or help would be greatly appreciated.
You can download a repair or owners manual at the kohler website.
You'll have to look around a bit for "Classic engines"
IIRC
1 - 2 of 2 Posts
