Need carb help on couple machines
1341 Views 4 Replies 3 Participants Last post by  buddyp
So I've done some searching but can't find what I'm looking for. First up I need a carb rebuild kit for an LT1000 with a 19.5 Briggs twin. The engine model is 42E707. The type is 1631 01. The code is 9705095B. I've found a couple different carb kits, but not sure if one of you guys know more about this engine.
Second, got a custom 10, not sure what year, dad got it in 85. Can't find a tag on tractor anywhere. Anyway, since we've had it, never Thad to take carb apart, just adjust every once in a while. But now it leaks fuel and constantly hunts. Probably best to just get a new carb if cant find rebuild kit. Where do you guys find parts for these things? Engine model # is 143-619012 and s/n is 0321 08221.
Third, got a SS16 I picked up for 100 bucks. Not sure what year. Need same thing lol, new carb. Tractor model is 91725751. S/n is 5061. Engine BF # is MS/2379B. S/n is 0473619039.
Any help is appreciated guys
On the Briggs, you have either a 3 or 4 screw fuel pump carb. kits are different.
Briggs part#-
3 screw 694056
4 screw 693503
The 2nd has a Tecumseh HH-100 engine.
3rd engine is an ONAN. Others will have tohelpthere.
I think I might be able to locate a link for a 917.25752. Should be very similar to yours.
EDIT-
I think stripmine may have this manual, but I lost all my bookmarks last week
Ok I found that info for the Briggs, didn't know if there was a way to tell by the numbers. I knew the others were Tecumseh and onan, but never knew it was a Tecumseh HH-100. Thanks for the help and let me know if you find that link
The Onan will have a Marvel DD-11 if it is original. A new one is ~$580.00 from Cummins. A re-build kit was ~$125.00 the last time I bought one but truthfully about the only parts you have to replace on those are the top gasket, O-Ring on the high speed needle, and needle valve and seat. Boomer can get you all of these.
Joe
Wow thats expensive lol. And I'm not sure how the carb really is. I cleaned it, but the intake manifold gaskets were ripped, so It wouldn't run right even if the carb was good. And who's this boomer guy, hear alot about him
