Does anyone have a wiring diagram for a 2355 that they could share? I'm trying to trace the wire that starts at the ignition (key) switch and ends up at the starter solenoid that supplies 12 volts to activate the solenoid and crank the starter. The wire goes into a wrapped harness and isn't visible to trace. I don't know if it goes from the switch directly to the solenoid or if it goes through a relay or something else. I don't seem to be getting a full 12 volts through the wire when the key is turned. There is an audible "click" and then 2 to 5 seconds later (while still holding the key in the start position) the starter will kick in and start the tractor. The solenoid and starter are both new. I'm thinking the wire may be corroded inside and not able to give a full 12 volts. If the wire goes directly from the switch down to the solenoid, I'll just throw a new one on and cut the old one without putting it into the harness.
Any suggestions, diagrams, or thoughts on this would be appreciated. Thanks and Happy Holidays!
Duane
Duane
