I bought an X540 this morning and the engine runs great but when the PTO is engaged, it stalls out unless a little choke is added for an instant. I have had similar problems like this before but before I get into the difficult areas I wanted to check with the team here to see if any of you have had this issue and what you did to solve it. The battery seems to be high on the list and it is an old battery so I will check that. Obviously, if it isn't the battery then it is a fuel issue since the choke will stop the problem. Kawa made getting to the fuel mixture screw very difficult and then put a plastic cap on it to boot!
