My new (to me) JD 650
1222 Views 7 Replies 4 Participants Last post by  lt230s
Hello guys,
Thought I'd post a few pic's of my 650. It has just over 2300 hours, starts and runs very well. I also got a 261 finish mower with the tractor. I purchased it for mowing and snow removal.
The only issue is that it needs a clutch. I have a strong mechanical background (My other hobby is building Street Rods & Custom cars), and a well equipped shop, however I've never "split" a tractor before. Watched a few videos on-line and read a few posts, just wondering if any of you have any words of advice from past experience? Also ant advice on a snow blower?
Looking forward to learning more about this little tractor.
Thanks much in advance!
1 - 8 of 8 Posts
Good looking 650. I've had mine 3 years or so and enjoy working with it around the place. We don't have snow often here in Ala but plenty of grass and it does a great job.
Clutch is no big deal. OEM Service Manuals are available (online) with good step by step instructions as to what to take off first. Following the service manual will save you a lot of time - it does matter what your take off first. All the fasteners are metric and the castings can be brittle so make sure you have the right threads in the right holes and use extreme care not to cross thread even the slightest - clean all holes and bolts with wire brushes and lube everything before going back up. Also observe torque limits especially on cast iron. I had several problems where previous owner tried to use the wrong bolts and broke out a couple of mounting holes for the belly mower. Using a pto grooming mower now - works better anyway! Pull the brakes while you are at it unless they have been recently done. Shoes are expensive but any good local reliner can rebuild them for far less than new (if you can find them). Major parts can be hard to find - Deere will take you to the cleaners on some parts if you let them - pays to shop around. Several good sources listed on the forum. Several good salvage yards in your neck of the woods are also good sources for hard to find stuff. You have no roll over protection but there is a place to install one. With the wide turf tires shes gonna be pretty stable but .... still a good addition There is a foldable ROP that will let you put it in a shed or low head room garage.
Good luck & have fun.
Flatires- Thanks much for all the info and advice! Greatly appreciated!
Well I tackled the clutch job today! Really wasn't as bad as I was expecting, about five hours start to finish. Only trouble I had was re-aligning the back half to get the input shaft back in the pilot bearing. After a little wiggling and height adjustment in finally slid back together. Here's a couple pictures at the halfway point.
Ooh! Tell us about the truck project behind it!
That's my 1957 Chevy 1/2 ton short bed resto-mod project. It's hard to see, but the completed chassis is behind my 650 in the one picture (under a plastic cover). It has a second generation Camaro front frame clip, ZZ4 Chevy crate engine, Turbo 400 and 10 bolt limited slip rear. The rest of the body is done and in primer ready for paint, I just have some metal work to do to the cab and it's off to the body shop.
Good work on the 650. Glad it went without too much of a problem.
Nice Chevy too. My dad had a '59 Apache.
1 - 8 of 8 Posts
