1 - 20 of 39 Posts
Murray tractor owner
Well I just got a 993 (I think) with 50" mower deck, Briggs and stratton 16hp twin, Comlete 3pt (exept draw bar and toplink) Where is the model numbers on this? It was a steal at $320 running only needing an oil change and a good coat of paint. It is a Beast!! I will get some pictures for you.
Discussion Starter · #2 ·
Here are some pictures!! (sorry for the bad pictures.)
Not bad at all, good find.
Ya done good, young'n.:fing32:
Thanks, Do you know where I can find a plow to fit? Where can I find the model number? It was a long drive to slippery rock but deffinatly worth it.
The Magnificent
Pull the deck off for us, and give us some pics of the front end and lift.
I might have a plow that would work on it.
Discussion Starter · #8 ·
Where would the model number be at? I can go check. It said 993 on the deck.
The Magnificent
That's likely part of the deck part number.
Model could be inside the hood, on the back end, or under the seat.
Discussion Starter · #10 ·
The Magnificent
MTD made most of the tractors Agway sells. You will not find an Agway specific manual. This tractor sold under other brand names as well.
Discussion Starter · #12 ·
Well it is not inside the hood, and I have to un-hook the seat because some one put it on a different frame then bolted it to it. Where would it be on the back end? on the hitch plate?
Discussion Starter · #13 ·
Now I have two agway GT -16's one is a murray!
Discussion Starter · #14 ·
What was the model and serial that you used to get that manual? :thanku:
Discussion Starter · #16 ·
Thanks. now all I need to do is sell the 845.
Discussion Starter · #17 ·
Does any body have a good picture or the 3pt? I want to make sure it is on correctly. Here is the Drawbar and the Toplink I will be getting for it.
Finally at 1k!
I hate you now. lol jk
I was trying to get one of them.
Its didnt work out.
Nice looking tractor! Never seen one 'branded' like that down this way....
Must have been a lot of dealers in Penn...I think my BIL has an older one , rusting away behind his shed..
glenn
1 - 20 of 39 Posts
