Should have a hook at the top and a hook at the bottom. I have thought of making a cable with turnbuckles to replace my wire rod...Yes, you can lube it. I use a lock nut on the bolt so you don't have to tighten it so much that it pinches the mechanism. It leaves it a little loose so it rotates.
