Saturday I bought my first tractor a 1964 4020, console shift syncro shift, it has a 148 loader on it and 5200 orig hours with a JD rebuild at about 5000 hrs. that said I don't know much about tractor and there are a few problems with this one and i haven't had time to really look at them but I wanted to get your advice on them.
1 - fuel leak, I had to drive it 20 miles from the auction to the house and I had to stop 3 time to clean the fuel off my glasses, I can see what appears to be fuel leaking from a small hole in the air cleaner where the oil is supposed to be, any ideas how its getting there? I believe its running a little rich as well is there any way to check this?
2 - I want to install a ROPS and replace the hood, any idea where I can find either one?
3 - 148 FEL, the tilt cylinders are leaking at the packing around the piston, is this a difficult to repair and are the parts available?
4 - the shift lever is difficult to operate and sometimes the gears don't want to engage can this be adjusted or repaired?
5 - I would like to get a repair manual for it, where can I find one?
6 - more to come as I work on it.
7 - is there anything you all can add to this?
Thanks for the help,
4020
4020
