Well I had fun mowing with my recently purchased 10545 Gold Series yesterday. It was running rough when I first got it and the engine brake bail was totally bent up and it broke when I tried to straighten it. I installed a brand new one, adjusted the cable, removed the tank and blew out the dust and crud from the engine, cleaned out the air filter box and filter, checked the muffler (it was clean), sharpened the blade and she roared to life on the first pull. It has a starter but the battery is shot and I can't justify the price of a new one when it's easy to start manually. I was surprised when I did a compression check and it indicated 125 lbs.! I'm guessing that's pretty good huh?
It's fun to mow with and I really like the three speed drive and throttle. I like to back off on the throttle in low grass but when I get into the heavy stuff I just bump it up to "rabbit" speed and listen to that engine power up under full load with no hesitation at all. Takes me back to my old motocross days. I'd love to try some Cam 2 racing fuel with Honda HP2 oil to generate the smell of racing again. It should be fine right. Racing fuel actually runs a little cooler than regular gas, just more power.
The only complaint I have is when I pull the mower backwards and the flap on the rear tucks under the deck it gets hard to pull. Obviously I release the drive bail but it's still hard to pull backward. I'll have to look closer but maybe the flap is getting under the rear wheels. Any expert advise about the reason for this?
