Congrats on your purchase! Those are nice little tractors. I have a G10 so if you need any parts let me know. They are very similar tractors.
1) I have seen several muffler configurations. Either the big muffler that I know was used on the larger G and H series as well as the 6$ mufflers available at any hardware store. I do not know which is correct for your model, but putting the cheap muffler on would require very little work. All you need is a piece of pipe that will clamp on the pipe that is there now that has the thread for the muffler on the other side.
2) I turned a bushing out of a piece of brass I had sitting in the shop that took up the play on one of my tractors steering. I sold it recently, time will tell how it works out.
3) The free wheeling pin is used if you have to roll the tractor. If you want drive to go to the wheels, then you will need the pin pushed in so that it locks the wheel hub to the axle. Be careful removing it and do not pry on it or you can snap the ear that is used to hold it in place.
Here is the parts manual for your tractor: http://sonnysbolens.com/manuals/images/tubeframe/1255.pdf
:wwp: or your tractor!
Jason
Jason
