1 - 3 of 3 Posts
Surprised that I never started a thread for this mower. It's a model 917.388650, and I bought it for $50 in November 2017. Has a Briggs engine: 123K02-0258-01-04051858.
This mainly gets used for trimming and bush whacking. It mainly gets used in places I don't want to take the tractor deck.
It has what appears to be a mismatched bagger (but it does connect just fine). This is a 21-inch mower (not 22), and is fully a manual/push mower.
Not long after buying it, the stop/control cable froze. I'd been able to run the mower since then by using a zip tie to hold the stop switch open.
Anyway, finally changed the cable today. I also changed the air filter and oil. I also replaced the fuel line and added a fuel shutoff valve.
Oil seemed pretty thin when I poured it out of the drain pan.
Also, the third pic shows the "clean" (carb) side of the air filter. I added grease to the edge of the new one to make it seal better (a trick I learned from someone here).
Probably needs a spark plug, but I didn't have one on hand.
Added gas, fired up on third pull!
Mike
Mike
View attachment 2459857 View attachment 2459858
I love those Quantums. Never had a problem with them.
Thanks! Funny, it occurs to me that I have no good pics of the whole mower and engine...
I have a 2003 Murray too (was my Dad's), also with a Briggs, but no bagger. I've abused that thing (he was throwing it away), and it never failed me until its cable broke. I replaced that, but it now has a fuel leak that I need to deal with. Separate thread here:
Mike
  • Like
Reactions: 1652
1 - 3 of 3 Posts
