This is a Murray tractor.
Engine Numbers are: 2-39003X92 2021
401707 0631 01 and then; 81038112.
16 Hp @3600 Rpm.
356 Cc’s.
The Coils Died. Both sides of the coil apparently. Does anybody know how to Ohm out these coils? What kinds of numbers should I expect?
It has a Ground wire, which is the Kill switch wire I think.
Then it has two Hi tension leads.
The Coil is one of the Electronic coils that has the small coil to act like points.
Thinking it might be rusted or poor grounds, I pulled the Mag off, cleaned the pads up with a wire brush, used some conductive grease and screwed it down tight with .006-.010 Air gap.
Still nothing. Not even weakly spark.
Am I stuck with replacing it?
Any help would be appreciated!
16 Hp @3600 Rpm.
356 Cc’s.
