It could be a number of things.
When did you change the oil in the hydraulic system last?
What did you put in there as these do not use hydraulic oil but motor oil?
Also be aware that these older machines did have an issue with the rear axle bolts breaking. In either case you should pull that apart anyway and do a repair on it.
It is mentioned numerous times in the archives here, but basically you pull the entire rear end out and replace the carrier bolts with a kit from Ingersoll. You can also PM BHildret of this forum and he can get them for you, then put a 1" weld on both sides of the carrier halves to keep any movement from reoccuring again. Caution of this is your issue don't keep running the machine as you can crack your case or put a hole in it.
Just a thought... if your tractor is a female then getting jerked around would be considered a normal operating procedure.
- Stay tuned for more replys.
BTW Welcome to the forum.
