I'm sure it is something simple but I can't figure it out. Hopped in this morning, fired it up, pulled out and parked it.
Now, Hop on, step on the brake, turn the key, lights light up but starter does not even attempt to operate. Lights come on on the dash, all the usual clicks but no starter.
Ideas?
First check the battery and the connections.
my 430 did the same thing it is very fussy on good clean connections i even had just put on new cables but the battery terminals looked clean but i brushed em off and that solved the problem ...again they are super fussy on good clean tight connections
Could be a loose wire on the connection to either the seat safety switch or the brake safety switch, or one of those safety switches has gone bad
