1 - 20 of 203 Posts
I started my 332 restoration! Here are a few quick photos before and during the disassembly process. The frame is bare, and I hope to start painting this weekend. The engine is still assembled, but it will be bored 20-over with new pistons, rings, and bearings at the very least. I plan on doing the valves and pump myself.
Here's how it looked when I got it last week:
Engine out of the frame and de-greased:
Organized parts....
Bare frame, ready for bead-blast and paint!
Wow, you are going all out. Search some of my past post and you will see the 332 I just completed. Keep the pics coming!
Here's a question for you. How did you get the brake rod that goes through the frame out? I tried for a couple of days and couldn't get mine to budge. Decided to just leave it in there!
Well, there's a roll-pin through the sleeve that the inner linkage attaches to.
-Sorry I really can't think of an easier way to explain it. Mine was caked in grease and dirt and I wouldn't have found it if I didn't de-grease everything before I got started.
Addictionado
That is a pretty clean look'in 332. How many hrs?
.......It's clean after 2 gallons of de-greaser and a few hours with a hot pressure washer :) The tractor has 3200 hours on it, the engine had some considerable blow-by and I thought this tractor was a perfect candidate for a full blown resto. I bought it 2 weeks ago and I hope to be done in Nov. for the Fall:praying:
Happy To Be Here
Awesome work, you are doing.
That is the way to get them looking good again.
USMC
Please keep us posted as you progress. That ought to look fantastic when your done with it. slkpk
Discussion Starter · #13 ·
I sandblasted and primed the frame and other black parts this weekend. I'm going with a high gloss black 2-part poly. I would like to have the rolling chassis back together again by next weekend, but that all depends on removing the rear brake drums.... I can't believe how stubborn they are!
Looking great so far, but you shouldn't have it on the wife's rug!;)
BTW, which brand of de-greaser did you use?
It's OK, the primer matches the pineapple:biglaugh::biglaugh:
Discussion Starter · #19 ·
Got the frame and other black parts painted tonight. I used Valspar Poly-Acrylic gloss black. Used my HVLP and sprayed at 40psi.
The pictures stink, but everything came out nicely. No runs, and no sags! :fing32:
I hope to start assembling the chassis this weekend.
This pictures was taken right after the final wet coat, once it dried most of the orange peal flattened out.
1 - 20 of 203 Posts
