93 GT 6000, 04 Craftsman DYT 4000, 06 Craftsman GS6500
Hello and thank all of you for making this site a wealth of knowledge and encouragement. You have added alot of excitement into my slow but sure plans to help restore some fun and cool pieces of history.
I first ordered a replacement ammeter as the one on the little tractor is broken and only serves to plug the slot in the dash curently.
I started checking the front hood mounting brackets and noticed they had been altered by a "conflict" with something fairly solid. Such as crashing into something. Fortunately it was a mild "conflict". I removed and straightened the brackets and reinstalled them.
I moved on to checking out the carburetor as the engine would only run on starting fluid. I noticed the choke shaft was frozen in the open position.
I removed the "air 90" elbow and carburetor to start a rebuild.
I was able to free up the choke shaft and thought I was making some progress. I soaked the float bowl screw with some penetrating oil and tried to remove the big bolt/ fastener holding the float bowl on. It barely moved. I soaked it some more and tried gently working it tight and loose a very slow amount. I wasn't getting much movement at all. Not even 1/16 of a turn! As I was trying to persuade it some more it "broke" loose. Literally! I soon realized the carb was broken beyond repair. It had broken the bottom portion off beyond repair.
I decided a new carburetor was in order and decided to give "Isavetractors.com" a bit of my business.
I had already researched the parts availability and felt that Norman had a good NEW replacement available for a reasonable price. I've ordered the carburetor and necessary gaskets so they should be here by weeks end!
Pics:
Pics:
