1 - 10 of 10 Posts
· Cranky Motorsports
I have been picking away at the minor little things on my new SS16 trying to get it all squared away. so far I have:
Installed new brass float (the fiber one was severely cracked and bloated)
Drained the tank out (it had water and flourescent green gas in it)
Replaced fuel line (it had vinyl or pvc line that was hard and rigid- held its shape when I took it out)
Replaced fuel filter with a sintered one
swapped the rear tires out because they were going flat
Tried to put the chains on that I got with it but they are for 20x8-8 tires so I think I will extend them or take them apart and make some killer chains for my ags
I tuned the carb, put in new plugs, new wires, and man does it run nice!
Now I found out the muffler has one blown baffle so I need a new one, or a stack :D and I need to change the oil.
It needs a new drive belt because it is a 1/2 inch one in it now so it feels funny when I let the clutch out but I have a spare correct size one, and the parking brake needs to be adjusted.
Getting there quickly - I really like this one!
The killer chains sound nice :) do you have a design in mind ?
Yes the good old ring chains with the corks are really good but you need to be careful because you can break an axle.
· That there's worth fixin'
I thought maybe sometime I could make some too. Make corks out of sawed in half plain links and weld them on the bull rings. Lot easier to just buy the duogrip style cross chains though. Expensive, but really nice and I bet they work awsome too.
I was maybe thinking of making 3 link chains, and doing similar to the first picture. I am not sure how they will sit in my lugs though. I hate customizing them though because cutting and welding links isn't really fun. I don't have bolt cutters so I have to cut them all with a die grinder LOL.
Christmas came early for me - got three sets of intake and carb base gaskets for my three Onans. I figure it's time I put new gaskets in there. had them apart so many times LOL..
I was in Community collage I rebuilt a set of ring chains from a big tractor, had to cut all the old worn corks off then make new ones and weld them all back on plus fix the broken chains as well. Very time consuming.
Discussion Starter · #9 ·
I "built" three sets last year- regular 2 links, but it's a chore!
1 - 10 of 10 Posts
