mowing with the 1250 and noticed oil dripping down in the deck- looked to me it was coming from the breather tube- it`s not attached to the air cleaner- I put a stick up their and wasn't anything coming from their- can quite a bit of oil be lost thru the tappet gasket?- or if my valve guides are worn- could this allow this space to get overly filler with oil?
also- can you have a cracked block- and the engine run? my other s-12d is getting oil from somewhere as I can see it hitting the exhaust elbow creating blue smoke- looks like it`s coming from the block just below the head
