Hi All, last fall I got the MW on an auction it needed some work to get it going so after repainting the Sears Suburban 12, I've got started on the Wards.
Had to remove the engine and the transaxle previously someone one worked on the engine and started to cut the blower housing, the ignition coil was dead and the alternator rectifier was also dead. Got blower housing off and found the wire from the coil to the points was broken and whoever installed the coil connect the coil ground wire to the points / switch wire got those things righted, repaired the housing cut, and added additional wire to the alternator wire to remote mount a rectifier.
The vari-drive system was stuck so had to remove the transaxle to get at the vari-drive, got it off but the pulley halves would not come apart figured out that the set screws that are suppose to hold the assy on the shaft had backed out over time and worn into the out half locking the two. Had no choice but to try and press them apart and I lucked out they did part and with min. clean up all is good again. The tractor is now going back together.
