1 - 2 of 2 Posts
redneckyankee
hi ya'll wanting to change my steering from to ball joints 1996 murray 12.5hp good running little machine but steering is very sloppy,, rods are just attached with cotter pins can these be changed to ball joint?? thanks for any info..[.
15,000 +posts!
If you mean it has a simple rod with a 90 degree bend that goes into holes in the steering knuckle ,etc,sure,you could chop it off a few inches shorter and thread it with a die ,so a threaded ball joint style tie rod end or heim joint could be used instead...or weld a bolt to the rod with the right thread for the ball joint ..
1 - 2 of 2 Posts
