1 - 3 of 3 Posts
I am trying to figure out my Neighbors tractor All of the sudden his tractor will not turn over, I put a Screwdriver to the solenoid post and it will turn over but with no spark any help would be appreciated. I checked for safety switches and there is one for the seat and Brake pedal, also checked the inline fuse and it is good
Old Iron......Forever
Can you check for the black wire going to the coil (under the flywheel cover) and pull it off and try? It could be grounding out from a bare spot on the wire. Or could be the key switch is bad. Check for power coming from switch to the solenoid for 12+ volt with key on.
check the wire to the head lights i put a new motor on mine and had the same problem when i took a step back to smoke and have a beer i relised that i had not put the hood on and bluged in the lights when i did that it fired right up no problems after that
1 - 3 of 3 Posts
