I picked up a Murray Ultra with a 15 horse Kohler that is blown. I have a 17hp intek on a scotts will the B&S interchange to replace the Kohler?
Thanks for any input..
Mike
Murray tractor owner
It should, Mounting holes might be different.
Not sure, but hankll will be along, he may know.
Old Iron......Forever
Shaft sizes are the same, I believe. Just need to check about the electrical connections. I'm having a block on whether they are the same basic electrical set up. I've had only a handful of Intecs in my shop, and never was dealing in a swap situation. Always was a same style swap or a rebuild going back into the same body. How the muffler works for the Ultra body might need a tweek on the tailpipe.
To be double certain, hit up a PM to Walt 2002, the man is a treasure trove of info also.
Thanks for the input
