nice tractor you got there $200 was a sweet deal
yes painted with rattle cans.next thing will be agg tires.That looks sharp. I like the nose red like that. $200.00 is a great deal. Looks like someone adapted another brands hitch, sweet that it has one. Is that rattle can paint?. It looks great. Can't wait to see more pics............
I Have Yhe Rest Of The Hitch Just Haven't Put It On YetI like the red! Hope the paint holds up on the nose piece. You need a bumper to prevent any bump into the grille. You need to find the rest of the sleeve hitch. I have some drawings of that and there was Pdf file I think that showed the dimensions for the sleeve hitch part itself that attached low. You just would need the lift link to connect to the pivot shaft.
These pdf files were some I was working on a while back ( for my Green Machine Murray) but was never able to get the missing dimensions, but I figured I could get the measurements pretty close by the scale of the pieces against the corresponding part.
I should give credit to DeckApe for the photo shots of the rear of his GT.
I've always wnted to see a set of AGs one one of the "modern" Murrays.yes painted with rattle cans.next thing will be agg tires.
If it's like my lt, which it probably is, there are 3 different holes where the spring from the idler bracket can attach to the blade engage arm. You can try a different hole to see if that helps. The holes are there to compensate for belts stretching due to age. Also, check the spring that attaches from the engagement arm to the deck for integrity [ie not stretched or damaged]. You may be due for a new belt. Hope this helps.i got the mower on and cut the lawn did a good job but have problem with keeping blade control lever engaged it keep jumping out anybody know how to adjust these i don't have a manual.:banghead3
Hank, you should consider installing a winch on the back to use for power up/down on the sleeve hitch. Only $59 at HF...$39 if you wait until Aug 27. This is one addition that you WILL like! As a bonus, if you get stuck, you can winch yourself out.I like the red! Hope the paint holds up on the nose piece. You need a bumper to prevent any bump into the grille. You need to find the rest of the sleeve hitch. I have some drawings of that and there was Pdf file I think that showed the dimensions for the sleeve hitch part itself that attached low. You just would need the lift link to connect to the pivot shaft.
