HI All,
I have the 48inch edge extra deck with Power-flow and 7 bushel bags on my X540. I use it to cut the grass, and collecting leaves for the last two years. Everything works well, except I now have a huge pile of smelly grass clippings.
So I thought it might be a good idea to consider mulching. I estimate it might take about 1 to 2 hours of work to remove the PowerFlow and install the mulching kit, and then reverse the process if I want to bag again.
So here are my question:
1) Is there a way to turn off the power flower without removing it? Is there a manual for the power-flow?
2) Is it possible to install a mulching cover (like the D100 series mulching cover) on the 48in edge deck? The D100 series mulching cover is just a piece of plastic cover with the rubber clips.
In the ideal world, if I can turn off the power-flow, and install the mulching cover, then I mulch and then quickly reverse it for bagging. Is this a workable solution?
What's the easiest way to switching between mulching and bagging? I see John Deere now offers "mulching on demand", but it is for the commercial mowers only as far as I can tell.
Let me know if you guys have some suggestions.
