1 - 2 of 2 Posts
I have a 2002 Conquest with the 44" deck. I have the powered bagger and am contemplating purchasing a mulch kit. The discharge does fine, but not fine enough and I like to return the clippings as much as possible. If I get the mulch kit, can I readily swap back and forth from/to the bagger? Obviously it can be done, but what would it entail? Would I lose suction performance? Any input would be greatly appreciated. Thanks
I would imagine you'll need to change the blades from the mulching blades back to the high lift, remove the mulch plug and reattach the blower/bagger. I'm always keeping an eye out for a second deck that can be setup for mulching as it would require less work to swap the deck.
1 - 2 of 2 Posts
