1 - 3 of 3 Posts
I see you are parting 1650 IH Cub Cadet on epay, but there are many,many parts listed and when I try to search for mufflers it gives nothing. SO, just wanna ask if you have complete exhaust for one and how much? I have the square tin it goes in, single cylinder Kohler. Not sure where it should come out, probly in grill somewhere? I don't have old one to compare.
Can you give me idea of what brands/models of tractors might have a Hydrostat system that is seperate from rear-end that I can use on my Power King late model? This PK uses shaft off engine and coupler at rear. Looking for unit that is complete drive to make it fit. I'm kinda wondering about using the Case hydraulic system, but not sure how speed/direction is controlled and if ALL of that system could be moved to anothr rig. I realize I would need to make brackets and control links.
Discussion Starter · #2 ·
Found mufflers, thanks, one even yours. searching for just 1650 narrowed down the parts choices lots better. Thanks. :thThumbsU
1 - 3 of 3 Posts
