That is likely water in the oil. I would change it, maybe twice and see if it comes back. Maybe it was left out in the rain?
Thanks @poncho62. That would explain the colour?That is likely water in the oil. I would change it, maybe twice and see if it comes back. Maybe it was left out in the rain?
I seem to think that I smell a bit of gas in it, but it's hard to tell. It's also hard for me to believe that a basically new engine is having carb problems, but who knows.If it was overfilled...it definitely not only could be gas in it, but most likely it is gas...can you smell gas in it?
If it is gas your needle valve is letting it pass through....definitely drain it and replace the oil and filter before running it and check the needle valve
Okay, so I think what I'm going to do, is change the oil, fill it to the right level, and leave it parked inside. Then I know for sure that it's not water, and if the level rises again by itself, then I know that it would likely be gas.Ethanol gas can be hard on carbs..the tips on most needles is non metalic and the gas eats them, causing them to allow gas to pass through
Thanks @ST1100A , I hadn't thought of that! Guess it's time to do some experiments...Another thing to check is the fuel cap vent. If the vent is not venting pressure out, it will cause fuel to be forced into the carburetor and blow by the float needle and seat, causing it to flood the oil with gas like that.
Wow, thanks ST; I didn't know that before... but it makes sense!You have to run the engine for a while when it is up to operating temperature to 'Boil off' any water/condensation in the oil. Same thing happens with an automobile and its oil.
When the engine is shut down and cools, it creates a vacuum in the crankcase and draws in air that has condensation in it. It condenses in the oil and on metal surfaces and has to be 'Boiled' back off/out by getting the engine up to operating temperatures again.
When the oil was drained before, there was still moisture inside the engine, and what the OP saw was the residue that was rinsing off. It will go away eventually as long as the engine is run long enough at operating temperatures.
That is normal in all engines, especially ones that are run for short times/distances and never get hot enough to boil all the water off/out of the crankcase and internals.
