The wife and I have decided to try a garden this year and I wanted to try breaking the ground using a brinly plow on a sleeve hitch. After finding out how much the CC electric hitch is and how much the Johnny hitch is, I decided to see if I could adapt the MTD/Arnold manual hitch to my 2500 series. I just couldn't spend over $1000 for a hitch and a plow...Not right now anyway.
I picked up a hitch at Lowes on clearance for $30. When I mocked it up, I found the biggest problem was the lack of holes for the hydrostatic dipstick and the transmission release lever.
Once I cut the two required holes everything lined up almost perfect.
I replaced the two upper bolts for the hitch plate with grade 8 hardware, 5/16 x 2 1/4 with 5/16 x 5/8 spacers to adapt to the shoulder bolt slots. I slid two 5/8 ID locking collars over the spacers to prevent any side to side movement. I also backed up the factory welded nut in the frame with another nut and washer just in case.
I then mounted the sleeve hitch as usual and it works!!!
I usually dont have good luck with these things, so I didn't take pictures while I was building this, only when I was done.
