I'm compiling a database of MTD front tine tillers produced from 1964 to 1984, and part of that would include the original engine specs.
For example:
1964 model year:
214-100 - 2.5 HP, no reverse, Briggs & Stratton model 80502 type 0141-01 engine
214-200 - 3 HP, with reverse, Briggs & Stratton model 80902 type 0148-01 engine
214-250 - 4 HP, with reverse, Briggs & Stratton model 100902 type 0137-01 engine
214-300 - 5 HP, with reverse, Briggs & Stratton model 140202 type 0137-01 engine
1965 model year:
215-100 - 2.5 HP, no reverse, Briggs & Stratton model 82502 type 0133-01 engine
215-200 - 3 HP, with reverse, Briggs & Stratton model 82902 type 0136-01 engine
215-250 - 4 HP, with reverse, Briggs & Stratton model 100902 type 0137-01 engine
215-300 - 5 HP, with reverse, Briggs & Stratton model 140202 type 0137-01 engine
1966 model year:
216-100 - 3 HP, no reverse, Briggs & Stratton model 92502 type 0180-01 engine
216-200 - 3.5 HP, with reverse, Briggs & Stratton model 92902 type 0173-01 engine
216-250 - 4 HP, with reverse, Briggs & Stratton model 100902 type 0137-01 engine
216-300 - 5 HP, with reverse, Briggs & Stratton model 144202 type 0140-01 engine
1971 model year:
211-100 - 3 HP, no reverse, Briggs & Stratton model 92502 type 0709-01 engine
211-200 - 3.5 HP, with reverse, Briggs & Stratton model 92902 type 0707-01 engine
211-255 - 5 HP, with reverse, Briggs & Stratton model 130902 type 0294-01 engine
Thank you,
Benjamin "Ben" Edge
I realize this is an old thread but the same number scheme continues through the 70s. I had a 213-100 with the 3 HP BS. Also, if you would like to see all possible models/configurations, search for the model numbers at hammerwall.com.
Discussion Starter #4 (Edited)
Yes, I have been perusing that website.
I have dug up some more info (and corrections to previous entries) since...
Model 214-100 (1964) has the B&S 80502 (2.5 HP), type 0141-01 engine.
Model 215-100 (1965) has the B&S 82502 (2.5 HP), type 0133-01 engine.
Model 216-100 (1966) has the B&S 92502 (3 HP), type 0180-01 engine.
Model 217-100 (1967) - same as 216-100
Model 218-100 (1968) - same as 216-100
Model 219-100 (1969) has the B&S 92502, type 0709-01 engine.
Model 210-100 (1970) - same as 219-100
Model 211-100 (1971) - same as 219-100
Model 212-100 (1972) - same as 219-100
Model 213-100 (1973) - same as 219-100
Model 214-100A (1974) - same as 219-100
Model 215-100A (1975) has the B&S 92902 (3.5 HP), type 1590-01 engine.
Model 216-100A (1976) - same as 215-100A
Model 217-100A (1977) - same as 215-100A
Model 218-100A (1978) - same as 215-100A
Model 219-100A (1979) - same as 215-100A
Model 210-100A (1980) - same as 215-100A
Model 214-200 (1964) has the B&S 80902 (3 HP), type 0148-01 engine.
Model 215-200 (1965) has the B&S 82902 (3 HP), type 0136-01 engine.
Model 216-200 (1966) has the B&S 92902 (3.5 HP), type 0173-01 engine.
Model 217-200 (1967) - same as 216-200
Model 218-200 (1968) - same as 216-200
Model 219-200 (1969) has the B&S 92902, type 0707-01 engine.
Model 210-200 (1970) - same as 219-200
Model 211-200 (1971) - same as 219-200
Model 212-200 (1972) - same as 219-200
Model 213-200 (1973) - same as 219-200
Model 214-200A (1974) has the B&S 92902, type 1484-01 engine.
Model 215-200A (1975) - same as 214-200A
Model 216-200A (1976) has the B&S 111902 (4 HP), type 0134-01 engine.
Model 217-200A (1977) - same as 216-200A
Model 214-250 (1964) has the B&S 100902 (4 HP), type 0137-01 engine.
Model 215-250 (1965) has the B&S 100902, type 0197-01 engine.
Model 216-250 (1966) - same as 215-250
Model 217-250 (1967) - same as 215-250
Model 218-250 (1968) - same as 215-250
Model 219-250 (1969) - same as 215-250
Model 210-250 (1970) - same as 215-250
Model 211-255 (1971) has the B&S 130902 (5 HP), type 0200-01 engine.
Model 212-255 (1972) - same as 211-255
Model 213-255 (1973) - same as 211-255
Model 214-255A (1974) has the B&S 130902, type 0453-01 engine.
Model 215-255A (1975) - same as 214-255A
~Ben
