Status
Not open for further replies.
21 - 40 of 40 Posts
Discussion Starter #21
Re: Poll Time, 318 dissassembly
Thanks Tim!
Video 19: Setting the valve lash.
Take this one for what it is or use it as inspiration. This video shows that if you can read you can do. While I had seen the valves installed before, I had never done it. No better way than learn by doing..... Although I have this sense of dread that this engine is going to go BOOM the first time I crank it... Even though its not (maybe) :)
Discussion Starter #22
Video 20: Onan Fuel pump and lines
Discussion Starter #23
Video 21: Belly Pan Removal
1/4 inch socket....
Discussion Starter #24
Video 22: Engine Removal Explanation
Technical difficulties shortened this one up. I eventually will remember to empty the memory card. :)
I also realized you do not need to remove the fuel line from the carb..... not sure why I did that.....
Discussion Starter #25
Video 23: Cylinder Head removal (and a couple discoveries)
Clearly someone has been in this engine. Now I am really interested to see if the pistons and rods are the same style.....
Discussion Starter #26
Video 24: PTO Air Gap
I realized there are a couple of good youtube videos already on this subject. But I was in the process of taking the PTO off so I figured ehhh might as well :)
Discussion Starter #27
Video 25: PTO Removal
Describes the process of removing the PTO assembly from the front of the engine.
Is there value in little videos like this. Taking the PTO off seems pretty simple. Rather than waste folks time I want these videos to be helpful. Is piddly stuff like this helpful?
Discussion Starter #28
Video 26: The elusive reserve pick up in the gas tank....
Discussion Starter #29
Video 27: Flywheel removal
Discussion Starter #30
Video 27: Removal of the Exhaust and Intake
Discussion Starter #31
Video 28: Electric Fuel Pump Overview on a 318
Discussion Starter #32
Video 29: Onan P218 Piston removal
Discussion Starter #33
Video 30: Camshaft Overview
The thrust washer was in the oil pan in pieces.
Discussion Starter #34
Video 31: Timing Cover Removal
Discussion Starter #35
Video 32: Valve removal
Discussion Starter #36
Video 33: draining the transaxle (nothing particually exciting)
Discussion Starter #37
Video 34: OEM 3pt hitch, rockshaft removal and other components
Discussion Starter #38
Video 35: Removing the front wheel
Discussion Starter #39
Video 36: Brake System Overview
Discussion Starter #40
Video 37: Checking Valve Specs
21 - 40 of 40 Posts
Status
