1 - 3 of 3 Posts
M85 won't crank, replaced ignition switch, no luck. I suspect neutral switch or PTO switch are bad or wiring damaged. Can anyone tell me where they are located, how to get to them?
Can you cross the solenoid contacts with the key on to get it to start? Could also be the starter relay.
I can start it jumping the solenoid. I put on a new switch, no help. Found the other 2 safety switches and was going to test them, but before I found time the starter switch is working fine. Strange, but I'll take it!
1 - 3 of 3 Posts
