Here's the copy from the following Moz-All advertisement intended to entice new dealers to carry these commercial mowers.
*****copy follows*****
Announcing The NEW 1950 SELF PROPELLED MOZ-ALL
Sell One Machine for ALL Mowing Jobs
CUTS WEEDS . . . With the blade guard removed, Moz-All is a powerful weed cutter.
Cuts weeds higher than your head. Sails thru thick, tangled grass.
Platform bends weeds over, blade snips them off, then pulverizes them.
Ideal for eliminating weeds from under fences, In orchards, and overgrown lots.
MOWS LAWNS . . . Moz-All is a highly efficient lawn mower.
Whirling blade sucks grass up, gives it a smooth, even cut.
Clippings are chopped into fine beneficial mulch and distributed evenly over the ground.
Eliminates raking of clippings. One to three inch cut.
TRIMS UP CLOSE . . . Moz-All trims close enough to eliminate hand trimming.
Cuts right up to walls, around poles, next to sidewalks.
Trims near flowers and bushes. Highly maneuverable.
MOZ-ALL Features That Move Money in your Cash Register
1 xxxxxxxxxxx Arrow points to capstan wheel driver
2 xxxxxxxxxxx Arrow points to handle control lever
3 xxxxxxxxxxx Arrow points to removable blade guard
4 xxxxxxxxxxx Arrow points to vertical shaft bearings
5 xxxxxxxxxxx Arrow points to movable belt pulley drive
6 xxxxxxxxxxx Arrow points to rear wheel
FREE SALES HELPS . . .
Write Today about the xxxphats MOZ-ALL program
WIND-KING ELECTRIC MFG. CO. dept 11250 MERRILL, IOWA
*****end copy******
Observe how the front is curved approaching the widest deck dimension. Unlike most mowers, you could gently and continuously push any Moz-All into fences while mowing along them without snagging on projections like unwanted volunteer trees which might grow along your fence line. If the side skirt were attached to the deck, the contact would just guide the mower outward enough to rub along the obstruction's edge. But if you removed the side skirt and used it in its "weed mower" mode instead of using it in its "mulcher mower" mode, the blade would chop off small trees while making lots of noise. The engine's drive shaft was protected from these impact loads by the twisted belt drive connection. Moving parts were fitted with grease zerks and even after 2000 hours, the rear wheels did not wobble. I expected stability might be a problem, but it was not. It was not more prone to scalping than other mowers. These were popular choices by city parks departments, gas & electric companies and other long-duty cycle users.
I've read that the first mulching mowers appeared in the early 1960s, and that Bolens claimed to make the first mulching mower in 1961. Obviously this 1950 Moz-All true mulching mower must not have existed in the same universe as them. Or maybe these revisionist historians are only talking about the "mulching mower" description, as distinguished from a mower that merely mulches. I think that's called a distinction without a difference. :thThumbsU Another advertising writer's victory.
While this advertisment lists Merrill, Iowa as the manufacturer site, I bought one without engine which lists Hull, Iowa as the manufacturer's site. On-line references to this excellent mower line also mention Sioux City, Iowa, a Nebraska town and Florida as manufacturing sites. I don't know why that is true. Perhaps the cast aluminum decks and other parts were sold by some maker as kits which could be assembled in little manufacturing sites. That's just speculation.
I want to repower the Moz-All I purchased without an engine. I think it was originally fitted with an engine with about 6 horsepower rating. Bear in mind, that both electric and gasoline motor & engine ratings have probably changed since the 1950s. If you're trying to replace a heavy duty 3 horsepower rated electric motor from that period with a currently produced unit, you often have to go to about a 5 horsepower rated motor to just pull the load. I've been told that same can be true of older gas engines verses currently produced engines. The difference is "paper horsepower" made of paper horses. I tried to fit a recent Kawasaki 7 horsepower rated horizontal shaft motor onto the Moz-All, but the Kawasaki is physically too large and the Moz-All's deck motor-mount bolt slots are for 3 1/8" wide by 6 1/2" long bolt patern engines, which is too small for that Kawasaki's engine. Thoughts of retro fitting a DuraForce Lawn-Boy engine to it which would require horizontal crankshaft mounting and altered carb appeal to my sense of the joyous absurdities in life.
John
