both my L130 and my X500 will do it.
if it is in dips only it is because the deck height changes as the tires go in and out of the dip.
if it does it in other areas it is because of high ground speed, cutting too much grass at once(over 1" being cut off), clogged/dirty deck, dull blades or any combination of the above. if you are cutting 2" or more off the grass you cna crawl along and it won't get anybetter. i found that when i need to cut really long grass it is best to cut with 1/2 the deck and let the other 1/2 cut back over where you jsut went.
and no, the x500 does not do it AS bad as the L130. with the x it does not happen until i am cutting 3-4" or more off the grass. and then only in thick moist grass/weeds.
