1 - 2 of 2 Posts
Not sure this is the right forum....
Not sure if this is the right place.....
Hi, I've somehow got my JD finish mower stuck on my JD PTO stub shaft. It always went on easy enough; it has a slip-sleeve type lock not a push pin. It must be stuck on a piece of tiny gravel or what? Never had a problem before....hadn't used it since early spring though.
Tried pouring greese on the shaft and slip sleeve, The sleeve moves up as it should to disengage the lock put I can't for the life of me pull the shaft off the stub.
Any suggestions. It is such a tight spot too I haven't yet figured out a way to try to force it off. Hard to do anyway with one hand moving the sleeve up.
:banghead3
1 - 2 of 2 Posts
