1 - 7 of 7 Posts
2 stroke addict
i have a Rally steel deck, and I am thinking of making a brush mower out of it.
I am thinking pneumatic tires, and a decent sized engine.
any input on engine and tires?
2 stroke addict
Ya know, i just happen to know where a 4bt is, and I have some 31's out behind my house.
A semi-retired senior cit
Yeah get at least a 5hp or larger motor, remove front wheels cut out the opening reinforce the cut out with 1/2" re-bar weld that in place then use existing holes for front wheels and make skids out out of flat stock I make them so you have 3" ground clearance. Now this will be a push type brush mower? The smallest brush mower DR had was, well they use to make was only powered a 9hp motor, guess it was a poor seller it not listed any longer. I`d also use the heaviest blade I could find, they take a beating and thin mower blade may even break.....think about that before starting project.
2 stroke addict
i could use a 10hp diesel If I can find one cheap, and use a RAGB to drive the blade.
yes, push type, but I have a 3+r Peerless 600 trans axle here that I could use to make it propelled.
1 - 7 of 7 Posts
