Here's a little info, the 54" deck (190-290-100 on a 3225) is in probably the worst condition of any of the decks I've seen, given its age of about 12 years. There are holes starting to form by the blade spindles and there is a large hole on the trailing edge of the deck by the discharge chute. All wheels/rollers are shot, as are the bearings on the forks (or bushings, not sure since I haven't taken them apart) that hold the front wheels in place. Those parts have been allowed to wear to the point where the forks have worn on the steel adjustment brackets on the deck, damaging both parts.
In other words, it needs a lot of work. So here is the deal, I was quoted 450 for the deck shell from the dealer. I haven't asked for quotes on the other parts that also need replaced, but all told it will cost between 600 and 700 to rebuild it.
I was also quoted 1300 for a new 190-295-100 54" deck that was told it would fit. Supposedly the only difference is that is the new one with the deck washing system. If I'm looking at buying a new one, I could also look at the 48" and 60". Our yard is small, at only 1/4 of an acre. Even a 48" is bigger than what I need. However, we are looking at buying more property and moving some day. We want at least 3 acres, but 10 or 15 is what we are really looking for.
So what do you guys think? Rebuild or replace? And if replace, would you keep the same size, go larger or smaller??? The snowblower is on the tractor already and this is the season to get ready for spring.
