Any help is much appreciated. This is on a 60" Cub Cadet 3235 deck.
The deck keeps throwing the belt off (under) the center spindle pulley.
Here is the belt configuration. The problem idler is the one next to the center spindle.
I replaced both the spindle pulley and idler pulley. The old idler pulley seemed out of balance and I think the bearing was starting to go out. The spindle pulley had a wore spot on the bottom edge.
After putting on the new pulleys & a new belt (the idler pulley bolt is perfectly straight) - it didn't change anything when I turn it over. Itthrows the belt almost instantly when under power.
When turning it by hand the correct direction - the belt runs low on the idler which is causing it to slip under the spindle pulley. When I turn it backwards - the belt runs right down the middle of the idler as it suppose to do. See the below video of me turning it by hand in both directions and watch the belt as you will see it change it's line around the idler as I turn it in each direction. The correct way is when the belt is moving to the left around the idler and onto the spindle.
http://s596.photobucket.com/user/du...80-5031-00000A0B62F64760_zps7f0766b4.mp4.html
I also checked the pulleys for being level with each other, They are close. The idler pulley is about a 1/16" off matching the spindle pulley keeping the face where the belt runs a little higher (angle wise) then the spindle pulley.
Spindle pulley:
Idler pulley:
Could that little bit be causing this? If it is, I think I will have to bend the deck surface to fix it.
Thoughts?
Spindle pulley:
Idler pulley:
Thoughts?
