you need 1/2 bolts and how long dependes on your rims
And it was this same style? That's just weird.When I bought the wheel weight kit from a dealer earlier this year, the kit provided threaded rod and mentioned that it was for either version of the wheels that came on the tractor. I assume you have the style with just the 4 holes for the carriage bolts, since that was what you were looking for. All of the hardware in the kit was 1/2", with 1/2-13 being the thread. I bought extra hardware for the kit, including additional washers, nylok nuts, flat washers and red locktite.
The wheels on my 3225 have the little triangle shaped cutouts, so I had to use these goofy angled pieces with holes in them to mount the wheel weights. If I had the other style and could use carriage bolts, I would thread them to the base, add a washer and nut, then put the weight on. It'd make the bolts act like a stud then to just bolt the weight to. Since I have the other wheels, I basically did the same thing with the threaded rod, nylok nuts and red locktite while using the goofy angle pieces. Even those needed work to make fit right...
I haven't seen anything like that. Here's a picture of a 2000 rim I found online and my 3000 rim for comparison.Yep, same wheel weights as you, sounds like different wheels though. Here are some pictures I've found. The cutouts are kind of triangle in shape. Would have taken pictures of mine but would have to take the weights off to do so.
I've seen 3000 Series Cubs with those wheels, in fact we have a set of those sitting around at the shop right now. Never occurred to me how much of a pain it would be to mount standard wheel weights to rims with those triangle shaped holes!Here are some pictures I've found. The cutouts are kind of triangle in shape.
You should just be able to just use carriage bolts for those rims (since they fit in the square holes on that rim.) This is what I did to mount my Bolens' Cast-Iron Wheel Weights on my GT2544 (I got a lot of flack here for the Bolens, but I liked the cast-iron weights over the plastic ones!I haven't seen anything like that. Here's a picture of a 2000 rim I found online and my 3000 rim for comparison.
Since the logo isn't raised, you could have just filled it in with Bondo before painting it. :fing32:(I got a lot of flack here for the Bolens, but I liked the cast-iron weights over the plastic ones!)
LOL! And I did fill in a number of the casting mistakes (due to holes and defects) in the cast-iron after I sandblasted them! However, I never really though about filling in the logo in the process since it didn't really bother me.Since the logo isn't raised, you could have just filled it in with Bondo before painting it. :fing32:
Aside from the wheel weight only being retained in two places (which I know should be enough because it is simply holding it in, the weight rests on the wheel), it was and is less than an entertaining experience if you remove the weights and the rods.I've seen 3000 Series Cubs with those wheels, in fact we have a set of those sitting around at the shop right now. Never occurred to me how much of a pain it would be to mount standard wheel weights to rims with those triangle shaped holes!
Likewise, there's a 2206 for sale in Cincy that has the 4-lug rims as well.For what it's worth, my 2186 has the solid one-piece style rim as pictured above in post #8, picture on the right. Is that the style of wheel you're hoping for?
I just cut the 10" bolts down to a reasonable size.JDfiles, any luck on mounting these up?
