1 - 3 of 3 Posts
I am looking to add some tie down points on the outside of the trailer that can accommodate large tie down straps like these.
What I am considering is weld on stake pockets cut in half to reduce cost or go with weld on tabs with a .5 grade inch bolt.
Any ideas as which one might be better or another option?
I like to use those with stake pockets, as you can drop the strap through the pocket, and when you pull from the other side, 90% of the time the hook will catch and you can just tighten it down.
1 - 3 of 3 Posts
