Hi all,
I've been able to laugh at my earlier post where I showed my mental handicapp. Trying to keep a sense of humor about it all.
I had just re-installed my re-re-re-built k-321 motor from the second rebuilder guy after his first attempt failed.
he asked me to deliver the carb, coil, cooling tin and starting motor so that he could run it on the bench and satisfy himself that all was right with this latest re-rebuild. The motor was ran and the report was that all went well with none of the observed previous problems and that the motor was ready for pickup. THe motor was re-installed lastnight in the 1987 224.
After throwing it IN gear, this afternoon
, I took it out for it's fifth maiden voyage on it's fourth rebuild in about as many months. I've posted on this sad lil tractor before and the results of this latest attempt by the newest rebuilder ended the same as all the rest.
After about 2 minutes of run time with the deck on for only a thin minute the motor started throwing oil out the crankcase breather assembly.
Shut the motor off and went into the shop to call the rebuilder. He now is keen to have me run it on a different muffler. His thinking is that the O.E.M. muffer could be restricting the exhaust enuff to cause enuff back pressure to create blowby and therefore pressurize the crankcase.
I'm working off that theory and will get an aftermarket for it at Tractor supply tomorrow. I'll post back the results in case it is helpfull.
Has anyone experienced this sort of thing with a case muffler? If it turns out to be the culprit all this time is there any way to clean it out?
Any advice, incense burning or consultation with the nut and bolt gods will be greatly appreciated.
I've also posted the motor troubles at the Yahoo kohler forum in case anyone's entertainement starved.
Thanks,
Tim
Thanks,
Tim
