1 - 3 of 3 Posts
Tractor Junkie
I had some time today so I removed the seat and fender pan so I could wash and inspect better also removed the gas tank to clean , I got it running from a temp hose to a fuel can, added some fluid for the hydraulics and she moved and steered so thats encouraging. I am think the PO just had new parts put in engine not a new one like he said. I also took a pic along with my GT2000 so you could get an idea of the size if the mule drive was removed there would be around 14" ground clearance
Ratchet Jaw old Member
Thanks for the pics Rcardo292, I like the looks of PowerKing, monster tires on them. :thanku::thThumbsU
Thanks for the pictures, I haven't seen one of the figerglass models up close before.
So the engine's output shaft is connected directly to the hydraulic pump? It looks like that is a much beefier pump than what is on the metal body tractors. Moreoever, it has a removible filter for the hydraulic fluid.
1 - 3 of 3 Posts
