To mis-shape the snap ring into an oval, there's either been some high speed turns being made, or someone put it on damaged.
The snap ring part number (from Deere) is W23122. The dimensions are:
Groove Diameter 0.906 IN
Groove Width 0.086 IN
Width 0.078 IN
Radial Width 0.151 IN
Free Inside Diameter 0.906 IN
The carb sounds like it might be a float stuck issue. If it was spewing fuel, the fuel pump, and fuel filter are letting fuel from the tank to the carb. If it was flooded when trying to start, it may have been a one time problem. Need a bit more information to give you a better answer.
Width 0.078 IN
