If you can enlarge the photo, it'll be easier to see.
A couple of my tractors have class 2 three points. To use some of my class1 stuff on them I modified a class 1 quick hitch to fit those two tractors. I widened the pin hole area to fit over the larger arms by stretching them apart with a Porta-Power mini jack and heat, then drilled the holes to fit a class 2 pin.
As I move my trailers around a lot and it's a pain using a truck, I cut a square hole in the cross bar and welded in a 2 inch hitch receiver. I just pull the pin when I don't need the ball to get it out of the way. Works great in both cases. PJ
I'd rather be threshing!
Great mod Paul! Very nice work!
Lost the photo, had to re-post to get it back. Sorry.
