That is a good looking and good size salt spreader! Nice design.
:thanku:for the pics!
...but the wood will rot from the moisture. You need to paint or otherwise seal up that wood, and keep a tarp over it.If you've done this before, then you know not to leave leftovers in it unless you like giant rocks made of salt--remember, salt is hydroscopic and will suck moisture from the air. I'd keep a broom handle around to poke it if it gets clogged up.Great idea. All wood, not rust from the salt............
the box is not complete by no means. I will post more pics when done. I plan on kilz primer then oil based safety yellow. Lining the inside with galv sheet metal. Adding safety lights to the back.
Yes I do have proper insurance. I am working through a larger company that services all of their maintenance needs.
:ditto:That is a good looking and good size salt spreader! Nice design.
