Then what Don? Restore them all? That sounds like a full time job for several months.Still need to find a 1953, 1954, 1958, 1963, 1966, 1968, 1969, 1971, 1972,1973, 1975, 1976 to complete the run from 1940 to the end of the C Models.
I would like to restore them but at about 3 months each, that would take a while.Then what Don? Restore them all? That sounds like a full time job for several months.
You need a capable assistant or two. Should be able to knock that down to as many weeks. The real time suck is the prep work. If I had nothing better to do for about 6-18 months I would volunteer.I would like to restore them but at about 3 months each, that would take a while.
Funny 3 of the 5 I have are ones you need.Still need to find a 1953, 1954, 1958, 1963, 1966, 1968, 1969, 1971, 1972,1973, 1975, 1976 to complete the run from 1940 to the end of the C Models.
Here's all of my numbers.
Steve, my '64 L8 is 629 off from your '64 L8. That's all I could find.
Huh well thats cool.:thThumbsU Phil's 64 L8 is off by 500 something off my 64 L8. (can't remember the exact number off hand hopefully he'll post his #s) Glad I called about that 64 L8 now.
Serial number plate would determine it. It seems that Gravely made a group of Cs in 1966 that used the L plates so that your 1966 would be marked L-8 if an L or LC-8 if a C-8. That low a number makes me think it would be an L-8.Funny 3 of the 5 I have are ones you need.
1966 6.6hp swifty trans J-170
1971 C8 J-69118
1973 C8 J-10979 ( must be missing a number in this s/n) gotta check it.
Would the 1966 be a C8 or a L8? I always thought it was a strange inbetween
model since it is still powered by a 6.6 engine but has a very early J-170 serial number.
Jason
The L-8 shroud should be a 64 unless it has a J number. If a 64 it would have a H-number.Here's all of my numbers.
Don't think I came to close to any of your numbers Don, everything was over 1,000.
Besides my tractors, here's the numbers off on my extra fan shrouds.
L- 46349/ 1949 (wish I had the tractor for this Shroud)
L- 51041/ 1950
L- 71553/ 1952
LI- M73906/ 1961
LI- M75465/ 1961
LI- 2M42281/ 1966
L8- 2M9880/ 1967? Was hard to read the # on this one.
Tractors-
1940 L 3180
1941 L 4656
1941 L 4760
1942 L 6348
1943 L 8380 Cast Iron Crankcase and steel wheels
1944 L 9453
1945 L 11673
1946 L 13988
1947 L 19821 Jenkins kit
1947 L 24309
1948 L 29496 Brass tag
1948 L 31010 Non-Brass tag
1949 L 42904
1950 L 53495
1951 L 63198
1952 L 67538
1955 LI 99172
1956 L M13674
1957 L SR1389 A 13207
1959 LI M46386 C 7860 Jenkins kit
1959 LI SR 5006 C 13207
1960 LS SR D 17238
1960 L SR8470 D 17639
1961 LI M75275 E 11824
1961 LI SR11076 E 15912
1961 LI SR11723 E 16858
1962 LI M86105 F 9400
1962 L SR13403 F 17633
1962 L SR13859 F 18102
1964 L 2M14574 H 6693
1965 LI 2M31829 I 10605
1967 CI J 14117
1967 C8 J 18617
1970 Cust CI J 58664
1970 Super C8 J 59566
1974 Super C8 105570
That's actually just a list of identifiable Ls. There are several more without tags.That's just wrong Don!! :fing32: :fing32: And that's just your list of L's/C's!!
Pretty sure I have a 68 and 72; probably also have a 69, but that machine's already bored 30 over, so I've got some decisions to make.
I bet if you talked to Richard at Richards lawn and garden or Todd White at Gtgravelyparts.com they may be interestedYou need a capable assistant or two. Should be able to knock that down to as many weeks. The real time suck is the prep work.
If someone needed 20 pcs or more then it would be worth my time to setup the wood turning duplicator. It just isn't worth it to turn 6 of them. It takes over an hour to setup the duplicator to make handles. I made a few dozen ships wheel handles for a fellow. He wanted them to match the remaining handles he had.
I don't know what wood was used to make the handle grips. If I recall the wood was rather soft. Maybe poplar? Does anyone know for sure?
I think some of them were partially painted. I just can't remember.
If you decide that you want grips turned, I will need samples of each so I can make a pattern.
