We've all seen some variation of one of these:
2460369
What are the possibilities of building an articulated tractor utilizing a 400 rear transmission and a 200 front transmission? What difficulties would mixing the two create?
If I remember correctly, the transmission is the same, but the hydraulic motor is different. The 200 spins faster I believe. Maybe use 400 tires on the rear and 200 on the front? But I'm still not sure if it would equal the same speed.
The Ingersoll Pictured has a hydraulic motor on the differential and the pump is located remotely so it does not require a drive shaft(s) and associated hardware. Only hoses.
