mitsubishi mt 160d what kind of oil?
3083 Views 3 Replies 3 Participants Last post by  Caustic
i recently picked up a mitsubishi mt 160d with a 3 cyl diesel it's a great tractor but it's needing an oil change, the manual says 10w 30 but it doesn't specify if i need 10w 30 diesel oil (like for diesel use) or regular gasoline 10w 30, don't want to put the wrong thing in, does anyone know which to use? thank you!
Don't sweat it, if there was some special formulation required the manual would specify it. API Service classification SD or higher will work just fine which is what most multi weight oils are.
You should try for an agriculture/tractor grade, ask your local tractor or petroleum dealer. 66 makes one called EC Fleetguard that is rated for tractors.
