Been doing some work around the house and cutting, routering and mitering trim to put up. Finishing up last bit for the day and bam. The plastic table insert shattered. Had the miter saw for about 15+ years and this is only issue I've had.
So went online to Ryobi site and couple others and the insert is no longer available. So after examining it, I see that it is just hard red plastic about 1/8" thick.
Wheels start turning and I remember I have some 1/8" plexiglass in the barn left over from some project. Go grab it and put it next to old piece and figure it should work.
There was enough of the old piece to be able to trace onto plexiglass. Rough cut with dremel. Finish up with rotary sander and file. Drilled holes to match locations on table and countersunk for screws. Finally attached and ran saw to cut slots as per owners manual. Removed insert and cleaned up edges of saw cut with file and reattached. Will test more tomorrow to see how it holds up.
Some pics. Old insert.
New next to old one.
New insert installed and ready for work.
