1 - 1 of 1 Posts
Precision Application
The ONLY handheld moisture testerthat offers accurate test weight
Whether you're harvesting, storing, or trading grain, nothing is more important to its value than its moisture content. With the mini GAC you can measure moisture quickly, easily, and accurately.
Features Include
  • Menu-driven operating system
  • An internal scale (no pre-weighing)
  • USB compatibility for calibration loading
  • Used for over 450 grains and products
  • Automatic temperature compensation
. . . And NO screw cap which can damage grains, create oily residue, and are cumbersome to use.
Package for the mini GAC plus includes:
mini GAC plus, grain funnel, carrying case, carrying lanyard, operator's manual, and one year manufacturer's warranty card.
Product Specifications
  • Measure Method: capacitance, conductance, internal scale, temperature
  • Moisture Range: 5-45%(depending on grain type)
  • Grain Temperature: 32-122 Degrees F (0-50 Degrees C)
  • Temperature Difference: 36 Degrees F (20 Degrees C) Instrument to grain sample
  • Temperature Compensation: Automatic
  • Grain Type: Whole Grain, no sample preparation
  • Sample Size: 1 Pint (0.47 L)Display: LCD (106x56 pixels)
  • Measures Parameters: moisture, grain temperature and test weight
  • Calibrations: 20 grain calibrations (choose from over 450 calibrations that are available)
Shop Grain Moisture Testers at Agrimart.net
1 - 1 of 1 Posts
